1995 Hyundai Lantra All Electric Windows do not work or in
LADYBIKER
Electrical problem
1995 Hyundai Lantra 4 cyl Two Wheel Drive Manual 68.990 miles
Think this is an electrical problem all fuses look ok but prior to me buying this car it had some work done under fuse box cover. I think it is an electrical connection problem under the fuse box area. Other things work ok but none of the windows go up or down. think the window motor is ok itself with the other item not working also. So could you give me a clue, Have checked all fuses and they are all in tact i am stuck
Mar 4, 2009 at 7:48 PM
JDL
  • 16,098 POSTS
Hello, did you check for voltage at the fuse circuits, use a testlite. There is a power window fuse 30 amp, underhood relay box, hot all the time. 10 amp fuse interior fuse box, goes hot when you turn on the key. There is also a power window relay in the passenger compartment relay center.
Mar 5, 2009 at 12:30 AM
