2005 Hyundai Getz belt squeaking noise
KOPS72
Noises problem
2005 Hyundai Getz 4 cyl Two Wheel Drive Automatic
I have this squeaking noise from belt and the noise only last for 5 to 10 mins after engine started and disappear after that.
This problem occur even after the belt changed recently.
Need your expertise of what exactly is the problem.
Many Thanks
Steve
Aug 30, 2010 at 7:59 PM
KHLOW2008
  • 41,812 POSTS
Hi Steve,
If the noise goes away after replacement of the belt and reoccurs after some time of driving, recheck the belt tension.
Check the pulleys for rust formation on the grooves. Check the crank pulley if equipped with harmonic balancer.
Aug 31, 2010 at 12:06 AM
