2004 Hyundai Getz CV joints
190,000 MILES • 4 CYL • FWD • MANUAL
THEODORA MODRAMOOTHOO
There is a noise when you turn it to the right and it get worse if you have to turn right on an up hill. Do I have the right and left compete CV joint replaced or just the right or is it only the outer joint.
many thanks and regards
Theodora
Aug 24, 2010 at 7:48 PM
EDWARD.S
  • 166 POSTS
Hi,I'd Start with The Right Axle First.Based On mileage ,It would not hurt to do both ,if affordable.But Go With Right Side First .
Hope This Helps You,
Good Luck
Edward S.
Aug 24, 2010 at 9:59 PM
