Hi
I have a very big problem in my lovely car.
One year ago an overheating start to come in my engine and this case is clear especially in the middle of the day in when the weather is too hot and the AC is working.
The problem that the mechanical guy try and error in my engine to solve the problem:-
1- The fan has been changed
2- Water pump has been change
3- Thermostat has been changed
4- Radiator has been changed
5- The engine head has been removed and turning then new Head Gasket
But the problem still exist
So finally he say for me he should make the below (note that our outdoor weather is too high approximately 104 F):-
1- Remove the Thermostat so no Thermostat will be installed in the car
2- Get the engine head out and put 2 Head Gasket instead of one
So please I need you help and advice shall I do what he say or do you have another solution please reply ASAP.
Thanks in advance
Thanks in advance
Feb 22, 2010 at 3:50 PM
