2004 Hyundai Excel the car won't start
2004 HYUNDAI EXCEL
12,345 MILES • 6 CYL • 2WD • AUTOMATIC
NGONGOYXAAC398
hi!
the car won't start eventhough we already replaced the computer box,coil, and thd cdi.what can you suggest about this problem
Aug 24, 2009 at 4:08 PM
Determine if its fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 24, 2009 at 5:30 PM
