1999 Hyundai Excel Replacing disc Rotors
1999 HYUNDAI EXCEL
270,000 MILES • 4 CYL • FWD • MANUAL
LOUISEDUDLEY
Want to know how to remove the Rotors.
May 2, 2010 at 1:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Loosen the wheel nuts slightly. Raise the front of the vehicle, and make sure it is securely supported.
Remove the front wheel and tire (A) from front hub (B).
Remove the split pin (A), then remove castle nut (B) and washer (C) from the front hub while applying the brake.
Remove the caliper mounting bolts (A), and hang the caliper assembly (B) to one side. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper from the undercarriage.
Remove the wheel speed sensor (B) from the knuckle (A).
Disconnect the tie rod end ball joint (C) from the knuckle (D) using the special tool (09568-34000).
Remove the split pin (A).
Remove the castle nut (B).
Disconnect the ball joint (C) from knuckle (D) using the special tool (09568-34000).
Remove the lower arm ball joint mounting bolts(A).
Remove the hub and the knuckle assembly (B).
To install:
Reverse the order of the removal procedure.
May 3, 2010 at 2:38 PM
