Radiator fans not working
1998 HYUNDAI EXCEL
WAZZA124
Engine Cooling problem 4 cyl Front Wheel Drive Manual
Fans do not switch on at all when a/c is switched on and radiator boils. Checked fuses not blown, hoses fine, can you help?
Jan 1, 2009 at 12:06 AM
  • 54,840 POSTS
This sounds like you have a radiator cooling fan motor that has gone out but to be sure use a test light and check for wiper at the motor when the air conditioner is on.
If there is power you need to replace the fan motor check out the guide below.
https://www.2carpros.com/articles/replace-electric-fan-motor
Please let us know what you find.
Cheers, Ken
Feb 17, 2018 at 2:01 PM
MONSTAKILLAHOMIE
  • 0 POST
Thank you so much for this guide, I replaced the fan motor now the car does not get hot ya! I love this site.
Feb 17, 2018 at 2:02 PM
RABBITTZ
My car overheated recently and cracked the radiator. I had the radiator replaced but now the radiator fans are not working. They were connected back in i have have checked and changed both fuses under bonnet. Am I missing something? Just can't get those damn radiator fans to work!
Feb 19, 2018 at 9:37 AM (Merged)
  • 31,937 POSTS
Check that the fan switch has not failed, check this first.
  • 31,937 POSTS
The switch I believe is in the bottom of the radiator, if not there let me know and I will look into it.
