1998 Hyundai Excel Immobilisor no longer works and I can't
180,000 MILES • 4 CYL • 2WD • MANUAL
INGRID10
I left my lights on and battery went flat. Road side assist came to jump start my car and when they put the jumper leads on I pressed my immobilisor before I turned the ignition and my immobilisor didn't work. ... This hadn't happened before.
The red light on the right dash that usually flashes is dead. Has my alarm cut out?
What are my options in fixing it. Disable the alarm? Replace the immobilisor system?
The Road side assist fella ended up hot wiring my car so i could drive home. I tried the immobilisor button again when I got home but there was still no movement.
Any help appreciated.
Ingrid.
May 20, 2010 at 8:55 PM
  • 110,246 POSTS
Is this an aftermarket alarm system?
May 21, 2010 at 6:04 PM
INGRID10
[quote:587d318fba="Jacobandnickolas"]Is this an aftermarket alarm system?[/quote:587d318fba]
Yes it is an aftermarket alarm system.
May 21, 2010 at 6:08 PM
  • 110,246 POSTS
That is what I thought. I wish I could help you, but there are so many different manufacturers, there is no way for me to gain information on your specific model alarm. If you are the one that had it installed, I would recommend contact the people who did it for you. Hopefully they will still have the information for it.
Again, if it was a factory part, I could help you. I'm sorry that it isn't.
May 22, 2010 at 3:39 PM
