my parking lights will not turn off unless i disconect battery.
Apr 7, 2009 at 9:35 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Hello
Thanks for the donation
Suspect faulty headlight switch. Turn switch to OFF position and test wiring to ensure no power is getting to switch. If power is to switch with it OFF then replace switch.
Thanks for using 2CarPros.com!
Apr 7, 2009 at 11:13 AM
VPBURN
MEMBER
is this the switch on the steering wheel?
Apr 7, 2009 at 12:34 PM
BLUELIGHTNIN6
The headlight switch is the switch used to manually turn on and off the parking lights and the headlights.
Apr 7, 2009 at 12:54 PM
