1994 Hyundai Excel will not start
65,880 MILES • 4 CYL • 4WD • AUTOMATIC
J&LCUSTOM
this is a 1.5 4 cyl new distribriter new coil timming marks in line power to distriberater.power to coil but no spark from coil plug or from dist. to plugs.my repair manual shows no diognostic plug in connector.all fuzes have been tested and are good.i did a compression test.#1 210 #2 190 #3 135 #4 150 lbs.fuel pump is good[electronic] and feul injected is up to reqi.specs.thanks joe 360-274-0402
Mar 27, 2009 at 7:17 AM
  • 110,248 POSTS
The compression doesn't look too good, but that doesn't affect the spark. If you have power to the coil and are sure the coil is good, try running a seperate ground strap from the coil to see if that changes.
NOTE: With the large variation in compression, the car will most likely run rough.
Let me know if this helps.
Jun 2, 2009 at 3:06 PM
