I have a 4 cylinder car, all three spark plugs are working well but one is not though it's new. Could it be the cable or the distributor?
Dec 13, 2009 at 2:10 AM
BLACKOP555
✓Experienced Mechanic
check the spark on that cylinder with a spark tester.
make sure it goes to a good clean ground. and the spark is bright and blue.
if nothing or a different color then blue spark check the wires ressitance and the rotor and distributor cap for wear or corrosion. switch the wire and plug with a different cylinder and see what happensl
