1994 Hyundai Excel MY EXCEL STOPS
1994 HYUNDAI EXCEL
BURAKERK
Engine Performance problem
1994 Hyundai Excel 4 cyl Front Wheel Drive Manual 130.00 miles
WHEN I GO,AFTER 15-20 MINUTES.IT PUSH OVER GAS
THEN IF I TRY TO PUMP THE GAS.IT IS STOPING THE ENGINE
AFTER 5 MINUTES I CAN START AND GO AGAIN
WHAT IS THE PROBLEM??
PLEASE HELP
Apr 25, 2010 at 7:21 AM
  • 110,244 POSTS
HAs the check engine light come on? Have you checked fuel pump pressure?
May 21, 2010 at 6:09 PM
BURAKERK
Thank you for yor answer
There is no engine light alert on the consol
Before 5 mounths I changed fuel pump
I didnt checked the pressure of the new one
Should I do?
One notice; When my car stops and push over the gass
I opened engine,I saw the fuel filter is empty(fuel tank almost full)
After 20-30 minutes ,car coolled
I am tring to start Firstly it is not starting after a while Again I try,The fuel filter cup became fully then the engine starts
Maybe on hot, the fuel pump cant provide enough pressure fuel?
May 21, 2010 at 10:27 PM
  • 110,244 POSTS
Did you replace the fuel filter near the tank? If not, it may be partially plugged. Also, I do need you to check fuel pump pressure. Here is a how to for checking it:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel pressure gauge. Most parts stores will lend or rent them to you. If you are unable to do this check, when the car refuses to start, see if it will start with starting fluid and let me know what you find.
May 22, 2010 at 3:30 PM
