Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Excel
Brakes
Caliper
Replace/Remove
1994 Hyundai Excel
1994 HYUNDAI EXCEL
135,000 MILES • 4 CYL • FWD • MANUAL
SKIRE_007
MEMBER
1 POST
how do you change front brake calipers
Dec 29, 2008 at 7:44 AM
Experienced Mechanic
Hi:
remove the caliper from the steering knuckle. Next, remove the rubber brake line bango from the caliper. reverse the order and bleed the air from the system and make sure the brake fluid is full in the master cylender.
Feb 27, 2009 at 11:20 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
