1990 Hyundai Excel sputtering-bucking
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
JCROSS8
i have an 1990 huundai excel with 72,000 miles (original) and in the past few weeks i have noticed a conciderable problem, basically, i have replaced plugs, wires, and most of the electrical system, i have noticed the car wants to sputter and/ or buck, and its not just at one particular time, it doesnt seem to matter, when its just started, running for a while, at a light, or what have you, could this be due to the MAF (mass overflow sensor) if so, where would this sensor be located?
Nov 25, 2008 at 9:49 AM
  • 110,248 POSTS
Hi:
It's hard to tell if that is the problem. Is the check engine light on? Also, have you checked fuel pump pressure? Here is a how to video:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find. Also, look and listen for vacuum leaks.
Feb 27, 2009 at 11:40 AM
