engine stalls after running for 10 minutes. then it usually restarts after a few seconds.
Feb 8, 2009 at 3:47 PM
✓Experienced Mechanic
Hi:
Has the check engine light ever come on? Also, if not, check the fuel pump pressure. You may have a weak pump or partially plugged fuel filter. Here is a "How To" video. The fuel pressure gauges can be rented or some stores will lend them.
