Hyundai Elantra Fuel tank
GATECRASHER
Other Category problem
Hyundai Elantra Engine Size unknown Front Wheel Drive Manual 120k miles
Hi, the problem I am having is regarding fuel backup in the tank. As I am fueling up my car, I can fill .3 gallons of gas and it backs up, causing the pump to stop fueling. Not sure what is causing this problem, any suggestions?
Dec 23, 2007 at 8:15 AM
BLACKOP555
  • 10,386 POSTS
first try different angles of the nozzle when filling and check to see the fuel filler hose isnt kinked.
if those are good you may have a restricted or shut check valve on the top on the fuel tank, also you may have a plugged, cracked, vaccum line going to it.
if those two are good then you have a bad carbon canister.
Dec 24, 2007 at 12:50 AM
