2008 Hyundai Elantra oil, filter change
2008 HYUNDAI ELANTRA
2,876 MILES • 4 CYL • FWD • MANUAL
JOHNHYUNDAI
Where is the oil filter located on the engine?
Sep 5, 2008 at 9:57 AM
VETRUJIL
Just changed one yesterday, it is located toward the front on the passenger side. You can see it if you look from the driver side. There is a plastic shield that you can remove to get at it. It has 3 10mm bolts.
[quote:e6e378c353="johnhyundai"]Engine Mechanical problem
2008 Hyundai Elantra 4 cyl Front Wheel Drive Manual 2876 miles
Where is the oil filter located on the engine?[/quote:e6e378c353]
Sep 22, 2008 at 6:32 AM
