2008 Hyundai Elantra My car makes a growling noise when i h
2008 HYUNDAI ELANTRA
35,800 MILES • 4 CYL • FWD • AUTOMATIC
DEHNIECE
I had a little issue with the driver's side of both tires, had to change both of them, but since then my car makes a growling sound when i hit 80 kmph, it reduces when i make a little turn to my left, the noise in the car is taking away the fun in driving and listening to music.
Aug 4, 2010 at 8:07 PM
EDWARD.S
  • 166 POSTS
Hi,From What Your Describing it sounds like your hub bearings making noise.they will make noise as you go straight down the road, the faster you go the louder it gets. if you only hear the noise when you turn ,like a clicking noise ,then that could be the front cv joints making noise. you need to take your car ,to a mechanic and have it checked out.
Hope This Helps You,
Good Luck
Edward S.
Aug 4, 2010 at 10:21 PM
