2007 Hyundai Elantra Air bag light is on
MATT N
2007 Hyundai Elantra 95000 miles
My battery died on me few days ago. Managed to jump start the car but noticed the air bag light is on after that. What should be done to solve this problem?
Oct 19, 2009 at 5:30 PM
  • 31,937 POSTS
Hi there,
Get a scan done to check for any unresolved fault codes if all ok, have a code clear done and you should not have any problems.
Mark (mhpautos)
Oct 19, 2009 at 9:18 PM
MATT N
[quote:5809e4005d="mhpautos"]Hi there,
Mark (mhpautos)[/quote:5809e4005d]
Was told scan can be done for cars equipped with "CEL" but Elantra whic dun hv any cud not. What else to do?
Oct 20, 2009 at 3:08 PM
MATT N
[quote:53d2f07173="mhpautos"]Hi there,
Mark (mhpautos)[/quote:53d2f07173]
Oct 20, 2009 at 3:40 PM
  • 31,937 POSTS
The air bag light on is a visual indication that there is a set fault code in the ECU, this can be scanned and a code will tell you what the exact problem is.
mark (mhpautos)
Oct 20, 2009 at 4:58 PM
MATT N
Already scanned with a scangauge, but no fault-no error codes displayed. What else cud be done?
Oct 27, 2009 at 3:12 PM
  • 31,937 POSTS
Hi there, did you use a scanner that reads body control module and not just engine /trans, if the light came on there will be a code, generic scanners wont always read every code, you may need a factory scanner or at least a top range unit to access the body control section.
Mark
Oct 27, 2009 at 4:06 PM
