2007 Hyundai Elantra after changing the headlamp bulb we ar
2007 HYUNDAI ELANTRA
108,000 MILES • 4 CYL • 2WD • MANUAL
BILLIE24295
We had to unhook the battery to replace the bulb then when we started the car back up many things will not work: A/C, Power windows, Power steering, tail lights, dash back light, and radio. All the fuses are still good. We are stumpped! When it was put on a diagnostic is didn't show any problems other than needing a new battery.
Sep 6, 2010 at 12:12 PM
KHLOW2008
  • 41,814 POSTS
Hi billie24295,
Thank you for the donation.
Symptoms indicates a power supply interruption.
Check B+ Fusible link ( 50 A) in under hood E/R junction box, in left front corner of engine compartment.
If fuse is good, unplug fuse and test for battery voltage at the terminals, at least 1 of the terminal must be hot at all times.
Sep 7, 2010 at 2:29 AM
