2006 Hyundai Elantra Rotor Removal
2006 HYUNDAI ELANTRA
41,000 MILES • 4 CYL • FWD • AUTOMATIC
PGUTMANN
What is the best technique for removing frozen brake rotors? I have an acetylene torch, but I am afraid that the excessive heat will damage the wheel bearings. Thank You
Apr 22, 2009 at 1:58 PM
BMRFIXIT
  • 19,053 POSTS
Remove the brake disc from hub using M8 screw if the brake disc has been seized with the hub to corrosion or overheat. .
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_312.jpg
Mar 31, 2021 at 5:36 AM
