Thank you for your suggestion of using an M8 screw.
Does this bolt go in the same hole that holds the set screw which seats the rotor on the hub?
Does using the M8 screw create pressure against the hub which causes the rotor to lift off the hub?
Or do you use the bolt as a lever-something to grag which helps loosen the rotor?
PS My donation was made on the first inquriy. Her's another one.
Thanks,
P.Gutmann
Thanks,
P.Gutmann
Apr 24, 2009 at 12:24 AM
