2006 Hyundai Elantra HELP
2006 HYUNDAI ELANTRA
49,000 MILES • 4 CYL • FWD • AUTOMATIC
KYLETRUG
WHEN I GP BETWEEN 60 AND 70MPH THE STEERING WHEEL SHAKES ALOT BUT ONLY AT THOSE SPEEDS. ALSO WHEN I GO IN REVERSE THE LEFT FRONT MAKES A SQUEEK SOUND
Jul 7, 2008 at 4:09 AM
KHLOW2008
  • 41,814 POSTS
Hi kyleTRUG,
You need to have the wheels balanced to rectify the steering wobbling.
The reverse squeaking noise should be due to brake pads almost worn out, the indicator is brushing against the rotor causing the noise. get the brakes checked.
Jul 10, 2008 at 2:46 AM
