2006 Hyundai Elantra
97,000 MILES • 4 CYL • FWD • AUTOMATIC
DEANER22148
This just started this morning: While moving, the heat vents blow heated air. But when I'm stopped, only cold air comes out of the vents. I suspect low coolant, but I'm not sure. What might be the problem? Is it low coolant, or something worse?
Thanks!
Oct 22, 2010 at 2:36 AM
KHLOW2008
  • 41,812 POSTS
Hi Deaner22148,
Did you check the coolant level in radiator?
Oct 24, 2010 at 3:58 AM
