2005 Hyundai Elantra my car
LOURDESB53
  • 2005 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 86,000 MILES
When I do the shifts it doesn't have enough power, it's real sluggish.
Tuesday, November 9th, 2010 AT 5:03 PM
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Tuesday, November 9th, 2010 AT 5:20 PM
Related General Content
