2005 Hyundai Elantra Low beams do not turn on, High beams w
77,000 MILES • 4 CYL • FWD • MANUAL
AEJHARGRAVE1
Last night I went to turn on my low beams and noticed that the lights turned on for half a second then both went out completely shortly after. I tested the high beams and the high beams work fine. Both lights went out very suddenly and at the same time. I don't believe it is a problem with the actual bulb since I actually replaced them about a couple of months ago. Any suggestions as to where to start with this or what it could be?
Thank you
-Ashleigh
Aug 18, 2010 at 8:35 AM
KHLOW2008
  • 41,812 POSTS
Hi aejhargrave1,
The high and low beams are on different circuits and have you checked the fuses and relay?
Aug 20, 2010 at 11:45 PM
