Can Not remove Tire from Car!
53,000 MILES • 4 CYL • FWD • AUTOMATIC
NEW2HIES
I followed the manual to remove the tire, however once I removed the 4 lugnuts, the tire is still tight to the hub and will not come off. What do I do?
Jul 19, 2009 at 5:12 AM
  • 110,246 POSTS
This isn't uncommon. The wheel has corrosion and has frozen to the hub. I use a dead blow hammer (hammerhead is full of sand,soft faced) and smack them off. NOTE: If you use a steel hammer, place a 2x4 between the hammer and the wheel so you don't damage the wheel.
Sep 3, 2009 at 5:01 AM
