2004 Hyundai Elantra Water leaking onto floor board when tu
2004 HYUNDAI ELANTRA
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
PURPLE_FAIRY
I need some help to determine what is wrong with my car and how to fix it.
When I have my fan or air conditioner on and the dial turned to cold (no matter how cold) and I make a left turn, water pours onto my passanger floor board. It appears to be coming from behind the Glove box, but nothing in the glove box gets wet.
I don't know why its doing this.
Please help.
Jun 2, 2008 at 1:49 AM
KHLOW2008
  • 41,814 POSTS
Hi purple_fairy,
Most probably the condensation drain hose is clogged resulting in accumulation of water in the cooliing coil housing.
Below the cooling coil housing is a hose which leads out through the firewall. Ensure that it is draining water out. The flow should be fast.
Jun 2, 2008 at 4:19 AM
