2004 Hyundai Elantra Replace thermostat, where is it locate
TJDONEGAN
Engine Cooling problem
2004 Hyundai Elantra 4 cyl Two Wheel Drive Automatic
Replace thermostat, where is it located?
May 16, 2009 at 8:49 AM
KHLOW2008
  • 41,812 POSTS
Hi TJDonegan, Thank you for the donation. The thermostat is located behind the thermostat housing on which the ECT is installed. It is attached to the lower radiator hose. Remove the lower radiator hose and the housing attached to it you would get the thermostat.
https://images.2carpros.com/forum/automotive_pictures/192750_ECT04Elentra_1.jpg
May 16, 2009 at 7:14 PM
