Had clutch replaced, than a day later I noticed gear oil in driveway (I know gear oil smell). Local lube shop said it was a badly leaking transmission seal & topped it off. Went back to repair shop lot - there was gear oil spot where my car had been parked for customer pick-up. How likely is it that the seal was damaged during clutch replacement? Should this seal be replaced as part of normal clutch replacement?
Oct 18, 2010 at 3:14 AM
