2004 Hyundai Elantra fuel
82,500 MILES • 4 CYL • FWD • AUTOMATIC
HAVASUDAVE
engine act likes it is running out of gas had to pump gas petal on drive way to get back up to the house
after filling up with gas strong gas order for a short time
runs good except for this problem this has happen 3 time had code check no codes fround new plugs and wires thinking fuel pump
thanks havasudave
Aug 23, 2010 at 5:29 AM
  • 110,248 POSTS
When you fill the tank, do you stop when the pump first clicks off?
Aug 23, 2010 at 3:55 PM
HAVASUDAVE
yes and it did it and it doesnt matter how much gas is in the tank gas gauge works but the gas milage hasnt drop that is why i think it si the fuel pump it will do it with the ac off or on and with cruse control on or off
thanks havasudave
Aug 25, 2010 at 5:40 AM
  • 110,248 POSTS
Start with checking fuel pump pressure. Pay attention to pressure drop off. That is when the key is turned off and the pump stops. THe system should hold pressure for awhile. If it quickly drops to 0psi, there is a fuel leak.
Let me know what you find. If you need directions, let me know.
Aug 25, 2010 at 1:11 PM
