2003 Hyundai Elantra windshield washer fluid system
2003 HYUNDAI ELANTRA
120,000 MILES • 4 CYL • FWD • AUTOMATIC
TEDBAG
The windshield washer fluid does not spray out. The most I can get is a small dribble after I blew some air through the tubing in hopes that it was just a clog somewhere. What can be done to remedy this? Where are the major parts (Pump, motor, etc) located and how can they be accessed? Thanks
updated 3/11/09
Thanks,
I was able to squeeze my hand in from underneath the car and access the pump
Feb 25, 2009 at 4:20 AM
  • 110,244 POSTS
The pump is at the bottom of the solvent bottle. If you have no access from under the hood, see if you can get to it from the inner fender. Once you get to it, see if there is power to the motor. If there is, replace the motor.
Mar 6, 2009 at 2:48 AM
