replace door handle cable to latch
RRICH8911
Interior problem 4 cyl Two Wheel Drive Automatic
Replacement of cable from door handle to latch. inside driver door handle.
Jan 25, 2009 at 11:30 AM
  • 55,554 POSTS
Hi RICH,
You must start by removing the door panel, here is a guide to help you with that with instrucions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/door-panel-removal
Then remove the control rods and wires from the latch. Once that is done remove the outer bolts to the latch and it will come out
Here is a video of the job being done on a similar car
https://youtu.be/XcujVZB7k60
Feb 13, 2017 at 11:53 PM
