2003 Hyundai Elantra rear brake drum removal
2003 HYUNDAI ELANTRA
63,000 MILES • 4 CYL • 2WD • MANUAL
CURIOUS1IAM
I just purchased a manual and i am still unclear on how to back down the rear brake shoes in order to remove the drum. I am assuming that removal of the "big nut" is not necessary. The rubber plug in the backing plate seems to only reviel brake shoe condition. Thank you in advance for your help!
Jul 12, 2008 at 3:02 AM
MASTERTECHTIM
  • 4,750 POSTS
you should be able to hit the drum with a hammer in the center near the studs but be sure not to hit a stud and then the drum should pop off. just a good jolt and it frees it up
Feb 25, 2021 at 3:12 AM
