2003 Hyundai Elantra instaling an engine
76,000 MILES • 4 CYL • 2WD • AUTOMATIC
SPOUZMAI
hello
I installed engine on the car, but as soon as I tightened the engine to the transmission, I heard loud clicking sounds. And neither the tourq converter nor the engine would turn. When I loosen the transmission from the engine, then the engine started turning and the tourq converter started turning. But when I tightened the engine with the tourq converter, the tourq converter would not turn again. Please let me know what I am doing wrong?
Thank you
Mar 27, 2010 at 11:43 AM
  • 110,246 POSTS
The converter keys into the front pump. If you are not aligning it correctly, there won't be enough clearance and it will lock up.
May 21, 2010 at 5:55 PM
