2003 Hyundai Elantra Ignition Coil Readings
80,000 MILES • 4 CYL • FWD • AUTOMATIC
WHERESBOBCARLSON
I have tried to test my ignition coil on my car. I know I was not supposed to take a wire lead off of the ignition coil, but it was the only way I thought possible to obtain a reading since it has no other terminals. Would I read the OHM outputs by unpluging the individual pack electrical connectors or how would I do this, they are non-can type packs. I know that the ignition coil packs say that they are 12 volt packs, if I took a reading with the engine running and all of the posts read under 10 volts DC, could this be bad coil packs?
Jul 10, 2010 at 2:12 PM
BLACKOP555
  • 10,386 POSTS
if it isnt getting 12v to the connector with key on engine off on the power side then the wiring is bad.
Jul 12, 2010 at 12:34 PM
