2003 Hyundai Elantra Cold Start Engine Squealing
99,000 MILES • 4 CYL • FWD • AUTOMATIC
SG9798
When I start my car on cold days (30 degrees) there's a loud squealing noise coming from the engine. It seems to get worse each day and sounds pretty bad and annoying. I had the power steering pump and the belt replaced several weeks ago. This solved the problem for a few days and then the squeal was back. Someone mentioned that it may be a CV joint? It worries me that the mechanic didn't fix the problem. He checked the car over and told us everything else looks fine. Timing belt, etc. Any ideas what could be causing the squealing noise?
Jan 24, 2010 at 1:46 AM
  • 110,248 POSTS
You are describing a belt squeal. The new belt may have stretched. The most common belt to make noise on start up is the alternator belt. If you have a seperate belt for it, check to make sure it is tight and in good condition. Check all belts to make sure of their condition and that they are tight. My guess is the alt belt.
If your car only has one belt, a serp belt, have the automatic tensionier checked or if it is a manual adjuster, it may just need tightened.
Also, the CV joints will not squeal on start up. Infact, they never squeal. When they are bad, they make a clicking sound on turns.
Let me know if you have other questions and if this helps.
Jan 27, 2010 at 5:53 AM
