2003 Hyundai Elantra
GTKOPECKI
2003 Hyundai Elantra 4 cyl Two Wheel Drive Manual
Sometimes, more often than not lately, I will be driving and it is almost as if I am in neutral. When I press the gas it revs the engine like I am not even in gear. It does not matter what gear I am in. It doesn't do it unless I push the pedal down to go faster, as if to pass someone. Do you have any ideas?
Jun 6, 2008 at 6:40 AM
DOCHAGERTY
  • 9,606 POSTS
The clutch is the possible culprit here. It may be slipping and if so will require inspection and possibly replacement.
Jun 7, 2008 at 8:29 AM
