2002 Hyundai Elantra wheel size
GRSMNKY
  • 33 POSTS
Tires and Wheels problem
2002 Hyundai Elantra 4 cyl Two Wheel Drive Automatic 76.000 miles
The standard tire size for my car is 195 60 15. I have bought a replacement steel rim to replace my damaged one that is a 5.5 and not a 6.0 which is recommended. Right now I have one wheel that is 5.5 and the other 3 are 6.0. The smaller wheel is mounted on the back of the car which is front wheel drive. My question is, other than premature tire wear on the smaller rim (car not equipped with ABS), will there be drivability problems or extra car components wear due to this mismatch?
Jan 28, 2009 at 3:54 PM
SERVICE WRITER
  • 9,123 POSTS
I don't see why you should have any problems. The diameter is the still the same. As long as it doesn't rub on anything, I wouldn't worry about it.
Jan 28, 2009 at 9:53 PM
