2002 Hyundai Elantra rear oil seal
2002 HYUNDAI ELANTRA
164,000 MILES • 4 CYL • FWD • MANUAL
SWTTANI
how do you change a rear oil seal.
Jan 29, 2009 at 2:02 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a3c3159e1c="swttani"]Engine Mechanical problem
2002 Hyundai Elantra 4 cyl Front Wheel Drive Manual 164000 miles
how do you change a rear oil seal.[/quote:a3c3159e1c]
In order to change the rear main seal you have to remove the Transmission, the Clutch and the Flywheel before you can even get to the seal. If this is something you are going to attempt let use know and we will help you through it.
Jan 29, 2009 at 2:15 PM
