2002 Hyundai Elantra power steering
102,000 MILES • 4 CYL • FWD • AUTOMATIC
JOSEFELICIANO
What makes the power steering squeal when you turn -- Car has plenty of fluid-
Sometimes the power steering belt actually stops for a second
Aug 30, 2010 at 12:05 AM
WRENCHTECH
  • 20,760 POSTS
90% of the time that is caused by a loose or bad belt. If the belt is good and adjusted properly, then you could have a bad pump seizing up but it's more likely a belt problem.
Aug 30, 2010 at 12:44 AM
JOSEFELICIANO
Thanks wrench tech
Aug 30, 2010 at 11:36 PM
WRENCHTECH
  • 20,760 POSTS
Your welcome
Feedback is appreciated
Aug 30, 2010 at 11:58 PM
JOSEFELICIANO
Hey wrench tech
Accordiing to mechanics from Hyundai
they recommend replacing the steering rack which
is what casues the power steering pulley to seize-hestiate and squeal when turning
Thanks for your time and consideration
Sep 3, 2010 at 8:43 AM
