2002 Hyundai Elantra oil pressure warning light
POPPY11713
Engine Mechanical problem
2002 Hyundai Elantra 4 cyl Front Wheel Drive Automatic
After oil change and oil level is ok. The car is not running hot. The oil pressure warning light sporaticly comes on and off. The mech told me the sensor could be damage and need to be replaced. I don't know, i feel there is more here.
Feb 16, 2009 at 1:22 PM
  • 31,937 POSTS
Hi there,
Have the oil pressure tested with a mechanical gauge, this will give you a true indication of engine oil pressure, if OK, the sender will probably be faulty.
Mark (mhpautos)
Feb 16, 2009 at 5:18 PM
