2002 Hyundai Elantra crank shaft pulley
HOOVAS
Engine Mechanical problem
2002 Hyundai Elantra 4 cyl Front Wheel Drive Manual
I'm trying to change the timing belt and can't remove the crank shaft pulley. How do I stop the engine from moving? it is in gear and all wheels are blocked. Is it reverse thread?
Aug 16, 2008 at 4:41 PM
  • 31,937 POSTS
Hi there,
You will have to get a large air impact driver or remove the starter and lock the ring gear with a suitable lever, there are other ways of removing this nut but they are dangerous and should not be attempted.
Mark (mhpautos)
Aug 16, 2008 at 7:18 PM
