2002 Hyundai Elantra catalytic converter
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARIA CALLENTE
i went to get my car check cause it need a smog check they did a quick check because my check engine light was on. they told me that my catalytic converter needed to be replace with a new one. how could i know if thats true and it that expensive to do.
Sep 20, 2008 at 9:27 AM
MERLIN2021
  • 17,250 POSTS
If thats the case the your car'scomputer has a catalyst effeciency code stored right? This means the 02 sensor behind the converter is switching too much. So it's either a bad sensor or a bad converter. The cost can vary wideley depending on if a direct fit, Hyundai part, or a universal converter is used. But I would ball park the job ar 600.00.
Sep 20, 2008 at 10:24 AM
