2002 Hyundai Elantra Brake issues
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JGALLOWAY1
I am going through brake pads at least every 3 months. I have replaced the calipers, rotors, and of course the brake pads. Also I have noticed uneven wear on the passenger side which is also the side that seems to need replaced more often? What is the problem? I have been told it could be anything from the master cylinder, improper caliper brackets, and even improper calipers. The last two seem very unlikely to me. Is there a brake assembly diagram available?
Oct 16, 2010 at 3:39 PM
KHLOW2008
  • 41,812 POSTS
Hi jgalloway1,
If the brakes wears out faster on one side, you need to check the brake caliper piston and slider bolt/pins for sticking.
Oct 17, 2010 at 2:26 AM
