2002 Hyundai Elantra bangs going in to 2nd [automatic]
125,000 MILES • 4 CYL • FWD • AUTOMATIC
JLMUST
My elantra sometimes not all the time,will rev up to 3500 rpm before it will shift into 2nd gear with a bang and the check engine lamp comes on,when you stop and start again,it starts off in 2nd gear.if you turn off the engine,most times it will correct it self for a while!
Oct 2, 2008 at 3:08 PM
2CARPRO JACK
  • 11,533 POSTS
Have it scanned for codes. Sounds like a solenoid that is sticking and the PCM should have recorded the failure in its memory (check engine light)
Oct 3, 2008 at 1:00 AM
