2001 Hyundai Elantra When filling gas tank, the pump keeps
2001 HYUNDAI ELANTRA
11,500 MILES • 4 CYL • FWD • AUTOMATIC
DEBBIECLEE
When I try to fill the tank the gas keeps turning off. I can get it in if I do it real slow but still keeps turning off.
Also I need to know how to change the valve cover gasket?
Aug 26, 2010 at 2:52 PM
  • 110,244 POSTS
For fuel to enter the fuel tank, air must escape from the tank. There is a vent hose that runs along the filler tube under the car. Make sure it isn't plugged, damaged...
As far as the valve cover, it is just bolted into place. When replacing the gasket, make sure the surfaces are clean and dry and do not over tighten.
Sep 1, 2010 at 12:05 AM
