2001 Hyundai Elantra wheel bearing
STONEFAERY
Tires and Wheels problem
2001 Hyundai Elantra 4 cyl Automatic 160000 miles
How do I replace my rear wheel bearing?
Apr 3, 2009 at 11:36 PM
BMRFIXIT
  • 19,053 POSTS
WHEEL BEARING
Removal
1.Raise and support vehicle. Release parking brake. Remove wheel assembly. Remove dust cap and wheel bearing nut. Remove brake drum and outer bearing (except models with disc brakes). 2.On models with disc brakes, remove wheel bearing nut and washer (if equipped). Remove caliper and disc. Remove hub and bearing assembly. 3.On models with drum brakes, pry grease seal from brake drum. Remove inner bearing. If outer bearing races require removal, use a brass drift and hammer to remove bearing races from brake drum.
Apr 3, 2009 at 11:45 PM
