HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Elantra
Drivetrain
Transmission
Clutch
2001 Hyundai Elantra clutch
WATSON9525
MEMBER
2001 HYUNDAI ELANTRA
4 CYL
2WD
MANUAL
115,000 MILES
Clutch is going out
Thursday, May 20th, 2010 AT 7:02 AM
MECHANIC
If the clutch is failing the gear box will have to be removed, a new clutch kit will have to be installed and the fly wheel re machined, if you need more info on this re post.
Mark (mhpautos)
SPONSORED LINKS
Thursday, May 20th, 2010 AT 9:23 AM
Please
login
or
register
to post a reply.
Related Transmission Clutch Content
Is This A Clutch Problem?
I Have A 2001 Hyundai Elantra And When I Get On Freeway And Shift Gears When In 5th I Have To Hold Gear Shift. If So, Is This Expensive...
Asked by
cbenjamin
1 IMAGE
2001
HYUNDAI ELANTRA
VIDEO
How to Check Your Clutch Operation?
Instructional repair video
GUIDE
Clutch Replacement
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all...
Transmission/clutch
I Have A 2002 Hyundai Elantra. I Shifted It Down From 3rd To Second And It Got Stuck In 3rd. I Popped The Hood And Checked The Shift Linkage...
Asked by
Switzer1988
2002
HYUNDAI ELANTRA
2001 Hyundai Elantra Transmission Temperature Sensor...
My 2001 Hyundai Elantra Has Had Some Shift Flares And Twice Gone Into "safe Mode" In About A Years Time. I Recently Had The Car In For...
Asked by
mike2001hyu
3 IMAGES
2001
HYUNDAI ELANTRA
2001 Hyundai Elantra Input Speed Sensor On...
Could You Tell Me Were The Input Speed Sensor Is On Transmission? I Have Service Code P0 715. Thanks
Asked by
chong1965
1 ANSWER
2001
HYUNDAI ELANTRA
Hihow Many Quarts Of Tranny Fluid Are Needed To Change...
Bought Used No Idea When Changed Last Or If Ever
Asked by
riebed
1 ANSWER
2001
HYUNDAI ELANTRA
VIEW MORE
SPONSORED LINKS
Clutch - How it works
Clutch/Flywheel/Rear Main Seal Replacement
Clutch and Throwout Bearing Front Wheel Drive
Online car repair manuals
