2001 Hyundai Elantra Battery cable stuck?
87,000 MILES • 4 CYL • FWD • AUTOMATIC
1COR47
I have been trying to remove the positive battery cable. It is different than normal cable connecters I am used to. It has a cup shaped head that fits down over the terminal and has a bolt sticking out of the top on which you loosen a nut. This is the only means I can see of loosening the head to remove it from the terminal but I have actually removed the nut and tapped and pryed and done everything I can think of to loosen the head and it still won't come off. I also tryed the baking soda/water solution to break down corrosion. Either it is so badly corroded that it is stuck on or I am doing something wrong in trying to loosen the head to remove it. I feel like I'm going to break the terminal right out of the battery if I pry any harder. Any ideas or experienced advice from anyone else who has used this type of cable would be appreciated.
Oct 8, 2009 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
Hi 1cor47,
Seems the terminal is stuck rather tight.
Reinstall the bolt and tighten it slightly. Release the bolt about 4 turns and tap at the bolt gently while trying to twist the cable to get it loose.
Oct 10, 2009 at 6:02 AM
